7" Indiana Jones 'University Dig' Custom Diorama By HembleCreations
324420692_671817984732223_42841214904602
"Hi All,
First build for 2023 and hopefully many more to come.
I have a few of the old Disney 7" Indy figures so I decided to start using them in dioramas. This one depicts Indy on an actual paid dig by the university.
Indiana Jones 7" scale.
Recipe.
Figure - is from Disney and is 7" in scale and I got him into a pose I liked and glued and covered the joints and painted and weathered him using Vallejo Paints.
Diorama - the main part of the base was built using foam board and then I used high density foam and cut out all the individual stones and glued them into place. Once the stones were all dry I then used watered down Spak Filla and dapped it over the stones to give them a more realistic look.
The soil/dirt was done using a mix of Spak Filla/sand/dirt and then applied it the areas and once dry I gave it a wash of Vallejo's Chocolate Brown and the vegetation is grass tuft and shrubs from Army Painter.
The relics/pots/skulls I got off Thingiverse and I resized them from 28mm to 7" scale using my 3D printer. The table/crate/lowering hoist are made from balsa wood and the rope is just some string I have had in my parts box.
The flames/torches/ where made using balsa wood and Woodland scenics Water Effects and the lantern was made using scraps from the parts box and I then added LED's to them.
Check out more images of their custom below in our GALLERY!
If you would like to submit your own custom figure(s) to be displayed on JediInsider.com, be sure to check out our Custom Forum section, where you can discuss and show off your work among other customizers.
