Tekkaman Blade Robo-DOU Figure From Threezero
JayC
Based on the 1992 anime series Tekkaman Blade! This fully-articulated Tekkaman Blade Robo-DOU Action Figure replicates its original design from the anime while accentuating its mechanical details! Tekkaman Blade is approximately 7 4/5-inches tall, utilizes a die-cast metal interior frame, and touts 74 points of articulation. It is constructed of ABS, PVC, POM and zinc alloy, providing a tactile durability as well as foundation for maintaining balance. LED light-up features are installed in the eyes, forehead, and the Voltekka shooting ports at both shoulders.
The figure includes a double-ended lance "Tekk Lancer," a "Tekk Shield, " and a whip-like "Tekk Wire." The Tekk Lancer can be separated into two blades while the Tekk Shield can be mounted on either the hip or on the left forearm. The Tekk Wire has a bendable and poseable metal wire inside, which can also be attached to the Tekk Shield. The fins at both sides of the ribs are interchangeable between closed and opened forms. Even the Crystal used in the anime for transforming into Tekkaman makes an appearance! You can pre-order this figure from our sponsor Entertainment Earth and get FREE SHIPPING when you use the code SUNFREE22.
The Tekkaman Blade Robo-DOU Action Figure includes the following accessories:
-1x Tekk Lancer (can be separated into two blades)
-Tekk Shield (can be mounted on the hip and on the left forearm)
-1x Tekk Wire (bendable metal wire inside for posing, which can attach to Tekk Shield)
-1x Crystal
-2x Pairs of interchangeable fins for the side of the ribs: 1x pair of closed fins, 1x Pair of opened fins
-2x Pieces of interchangeable hip covers: 1x Piece with a ball joint for attaching shield, 1x Piece without a ball joint
-3x Pieces of interchangeable left forearm covers: 1x Piece with a ball joint on the side for attaching shield, 1x Piece with a ball joint on the back for attaching shield, and 1x Piece without a ball joint
-1x Pair of fists
-1x Pair of weapon-holding hands
-1x Pair of action pose hands
-1x Pair of spear hands
-1x Left hand for holding the Crystal
