DCUC lantern heads
nonameshmo30
So i was thinking of makeing a few DCUC green lanters for myself and i was wondering what heads maybe good to use on a DCUC green lantern body. So if anyone has any pics of heads or even any heads they want to get rid of that may work show them here if you wouldn't mind so let me know.
Thanks guys
Thanks guys
Well, I plan on using the Romat-Ru head to make a Tomar-Re.
I've used some Marvel Legends and DC Direct heads for DCUC customs:
http://basementtoys.blogspot.com/search/label/DC
Basically DCUC, DC Direct, and Marvel Legends typically used a dumb-bell type neck post. It's a post with two balls - one on either end. One end fits in the head and the other fits in the neck. Check out the articulation on the DC Direct figure before you buy it though as some heads just move side to side.
I use the boil and pop method to pull heads off of figures. At this point - you may have to use a dremel on the head to make it fit if the neck post balls are larger from one figure to the next.
Good luck!
If you didn't see Romat-Ru yet check this out:
Yup I'm going to hold out for more GL two packs... I know they said they are not making any more two packs but I have feeling the gl 2pack will sell well... no reason why other corps figures would not :P There are plenty I'd love to have from the corps books :)
Thanks guys
wow and just the other day i was wondering what i was going to do with all these green lantern heads *pulls out a bucket filled with heads* ......why are you staring at me like that >.>
