Noob help
Darth Vehmic
I'm about to start on my first custom figure and I had a few questions:
1. How do I get the pins out of the joints and put them back in?
2. What's the proper method for removing limbs and heads?
3.What's the best method for painting a figure? Brush or Airbrush?
4.How do I remove the ball joints (around the groin and arms) and put them on another figure?
5. How do I switch hands and feet?
Any help would be greatly appreciated, thanks in advance!!!!!
remvoe pins by taking a pen and pushing the inner parts of the joint away from the actual pin. ball and sockets are just boil and pop.
as for painting, brush on the basic colors, and use the airbrush for shading and such.
The waist joints are different than legs/arms, you'll have to slice the figure in half or pry it apart somehow.
Also, if you have a high powered Hair Dryer, you can use it to heat up the joints instead of boiling and popping. I use an industrial heat gun myself, but I just happened to have one.
