6" scale scenery
MagnetoMasterOfMagnetism
The 6" Marvel Legends scale is also known as 1/12th scale, which is also known as Doll House scale.
Better stocked Hobby shops and craft stores that feature doll house items often have all kinds of items that can be used--like wall papers, furnitures, interior and exterior facades and stuff.
I have seen things like flashing, drain spouts, window and door frames and all kinds of exterior decorations.
IIRC, there should be working street light available, if you want to spring for the expense.
Of course, there are those items mentioned before in the Wrestling toys lines.
There's even stuff like vehicles--motorcycles to cars ( 1/12th to 1/14th scale will work) and I have even seen 1/12th scale tanker trucks and semi-trucks with trailers! That is if you need those kinds of things....
The trick with all the above is finding it.
Yes, you are right. :)
Vehicles in that scale are quite expensive... :(
