Symbiote Blast Venom Face Fix Tutorial!
Jin Saotome
Here's the final image of Venom with his new face fix! Not only does he have new teeth, he has an articulated jaw that can hold an open or closed pose, and a ball-jointed neck.
I did an entire tutorial about how to take the head off, make the teeth, etc. Check it out here!
http://www.angelfire.com/mech/jinsaotome/V...nomFaceFix.html
AWESOME, just awesome....that bad boy really looks killer. He looks better with the mouth open though, the mouth closed looks a bit odd for some reason.
You da man Jim. :D
God help me Jin....if you weren't a guy and your customs weren't just...y'know....plastic toys and all.....I'd marry you and put up an art show showcasing the customs.
Awww, what the heck? Let's have that showcase anyways!
Awww, thanks everyone! Read Venom's caption on the tutorial, there's a hole in the back of his mouth where you can plug the tongue in.
Someone make an Eddie Brock head, I wanna see that! The mask will easily fit over it.
sweet
Just glue Venom's head onto the inner peg of the ball joint, and the outer sides to the main body. It basically turns into a regular ML neck joint with up/down/side to side motion.
  • 1 month later...
