Luke Skywalker in X-Wing Gear 6"
  • Please log in to reply
2 replies to this topic
#1 hemblecreations
hemblecreations
    Andorian
  • Members
  • 179 posts
Posted 29 April 2014 - 05:13 AM
Hi All,
While on a routine patrol in the Melholtor System Luke's X-wing begins to navigation and thruster malfuctions, he and R2D2 try to repair the problem but to no avail. Luke decides that he will have to make a force landing on the 3rd planet of the Melholtor System and sends a distress call.
After the force landing in a small and shallow waterway Luke picks up a signal of a incoming landing craft and thinking it to be a Rebel Search and Rescue craft he is soon relizing that a Imperial Scout Shuttle has picked up his distress call and now are on his way to his location.
After ordering R2 to stay with the ship Luke starts to head of and find the Imperial crew but it only takes a few minutes before he realizes that they have found him so Luke pulls out his Light Saber ready to defend himself, R2 and his ship.
RECIPE
Figure - Luke is from Hasbro's 6" Black Series line and was positioned into a pose I liked and then the joints were superglued and then puttied. Instead of painting over the figure I firstly added thin strips of tissue paper by applying watered down PVA glue the tissue to give the outfit a more fabric feel to it, once the tissue paper had dried I painted and weathered the figure using Vallejo and GW paints.
Base - The base was done using left over foam core layered ontop of each other and glue togther using superglue. Once dry I marked out the feet and helmet areas and then cut the foam and removed the foam, I then inserted the figure and helmet using superglue.
The water was done by using plaster of paris to cover the base and just before the plaster dried I used a plastic spoon and lightly flicked it over the plaster to simulate movement in the water. I then used Woodland Scenics Water Effects went over the plaster waves so that it would give more of a ripple affect.
The ground work was done by using dirt and mulch from the garden and the plants and undergrowth are plastic fishtank plants and Army painter shrubs. Once all the plants were added the water was painted using GW paints and once dry I then used Woodland scenics Realistic Water mix with a little flat white to give the water affects a more frothy look.
Ron
  • Attached File  lx1.jpg   94.41KB   7 downloads
  • Attached File  lx2.jpg   103.02KB   5 downloads
  • Attached File  lx3.jpg   98.82KB   2 downloads
  • Attached File  lx4.jpg   97.15KB   2 downloads
  • Attached File  lx5.jpg   99.68KB   5 downloads
  • Attached File  lx6.jpg   97KB   2 downloads
  • Attached File  lx7.jpg   99.24KB   2 downloads
  • Attached File  lx8.jpg   92.48KB   2 downloads
#2 FUGAYZIE
FUGAYZIE
    The Gray Ghost
  • Members
  • 8,049 posts
Posted 30 April 2014 - 01:55 PM
beautiful work as always man!
#3 hemblecreations
hemblecreations
    Andorian
  • Members
  • 179 posts
Posted 01 May 2014 - 12:16 AM
Thanks heaps mate.
Rpn
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
